Tsunami Suggestions
clickclickw00t
Sup guys,
I have a Tsunami and I wanna put 2 UV lights in it (each 12 inches) and I need to do it without being able to actually see the physical lights. I wanna hide them somewhere in the case where I can't see the light fixtures, or wiring preferably, but there is decent amout of UV light cast into my case.
Any suggestions, pics, etc is appreciated :D
If you remove the useless intrusion protection thing you can get one between the the HDD cage and the bottom lip of the case.
Other one... well ive mounted them in the support bar that runs under the psu and also at the top between the psu and top lip of the chasis.
i dont wanna be able to see the fixture itself...
Post A picture of the case from the side. Is it on the floor or on the desk? I would like to see any windows possible. I am pretty good at hiding those but without Pictures it would be hard to give a reccommendation. If you dont get into the case very often and only have a small side window you can mount them directly to the edge of the side panel at the very bottom and top or at each side. If you do that just remember that you have them there when you get into the case so you can unplug them when you remove the side panel.
take the side w/o the window off and just shove it between that side and the harddrive/cdrom cage thing, stand it straight up. that where i have mine, give of a good amount of light and is not at all visable
