- Aug 17, 2005
I have noticed several times getting a higher score in FIRE STRIKE 1.1 using actually lower gpu clocks.....i have checked the log files with gpuz for valley and heaven benchmarks and the clocks don't appear to be changing or throttling...but its a little harder to tell with 3dmark since it changes screens and benchmarks and of course the clocks will throttle down like there supposed to in between the different tests...
why does it score lower with higher clocks even if gpuz log shows no throttling or is it something else all together that brings the score down?....truthfully im just trying to get the most i can from what i have is all...not like im lagging or anything or complaining.....just trying to understand it completely....and truth be told my 7970 is the weakest link in my system so im just trying to get the most from it ...without damaging it of course...for whats its worth i just put new past on and temps are staying at or below 70 for the most part now...so gpu temps should be ok....the voltage regulators on the other hand don't even have heat sinks on them....if i'm seeing them correctly...i guess the vrms are just overheating and making it very difficult to find the right overclock
