trying to understand freebsd
Cheetoz
how do i stop xorg without a reboot?
handbook states how to start it, but not to stop it
I usually right-click on the window manager background and choose exit.
sometimes when, say, the browser has frozen and pages are not loading,
cntl-alt-backspace
restart X
restart opera
opera offers to startup reloading all the tabbed pages. COOL
on a laptop, or sometimes when it is convenient, (a different window manager)
I use the command:
pkill X
if pkill is not installed, "kill #" (you get the number from ps, of the PID) although I just ran it
and it appears the number might be from Xorg not X
just installed gnome, but I get:
and
the screen resolution is too big! xrandr says its running at 2048x1536. I need it to be 1024.
I was trying to do Xorg -configure in order to fix it, but I couldn't get xserver shut down. I used xorgconfig --textmode to set some wrong settings, so upon reboot I stayed in terminal. Then I did Xorg -configure, but I just had a black screen. rebooting brought me back to gdm with this huge resolution
I don't use gnome. I use one of the lesser WM (simpler?), of which
I used several
default twm; /windowmaker/; fvwm2; [current one]
sorry no help.
as with the resolution, there is a keystroke which changes resolution. cntl-plus? I
forget really.
what i've done is find many xorg.conf's on the web and muddle together one
that sort of fits, then slowly fix errors. Sooner rather than later one that works
usually develops and I immediately back it up along with other pertinent files (xinitrc?)
I don't use gdm (yet) for the reason stated above (simpler).
call me crazy but isnt the error is right there
rename that .bbnet directory to say bbnet its the /. thats throwing it offf. you know slashdot
nope, thats the domain. :eek:
Resolution problem was due to vmware's drivers.
After fiddling with FreeBSD/Gnome I got tired of all the "hacks" needed, so I opted for PC-BSD, painless install og audio/Wifi worked out of the box on my Dell D630...:
http://www.pcbsd.org/
that or desktopbsd work pretty excellent out of the box. i prefer desktopbsd just because of the ability to use ports rather than using the pbi packages, but both are great!
BSD > * :).
Was thinking about trying out PC-BSD but as of right now don't really need it as I am running freeBSD.
If there was native installs for games I wouldn't need windows.
