I just did a fresh install of Windows for my Asus A8N32-SLI system.
I had a Norton Ghost boot disk from my previous system.
I have 2 hard disks (Drive C and Drive D).
I want to create a Ghost image of my Drive C and save it in my Drive D.
I booted up the system using the Norton Ghost Boot disk. It gets into Norton Ghost (Dos) but the program doesn't start normally. I can get into the program and the nothing happens. I can move the mouse and that is it.
My previous system was an Intel system (P5WD2-E). I had a similar issue. I solved it by changing the IDE setting from enhanced mode to compatible mode (SATA only) and that solved the proble. I could use Norton Ghost in dos mode easily.
Now I can't find any setting in the bios to change the IDE settings.
Can anyone help?
PS> I am using Norton Ghost 2003.
Can anyone help?
