Captain Colonoscopy
- Feb 19, 2004
So, I thought all 8xxx series nVidia GPUs were supported? I installed the GPU client and then open it to configure and it says my GPU is not supported or I need to update my drivers. So I go to nVidia and download the latest drivers for Vista x64 and install, reboot. Fire it up again and get the same problem. Is x64 not supported or something? Does the 8600 not work with the GPU client?
Here is the exact error message:
At present your GPU is not supported or you need a current driver. You may wish to consider running our standard client, which you can download at folding.stanford.edu.
I am running a X2 3600+ that is OC'ed to about 2.4GHz, 2 GB RAM, MSI 8600GT, Vista Ultimate SP1 x64.
Any help or insight would be greatly appreciated. Spanks!
