Trying to put new system list together.
Joni Nitro
Hey folks,
I am interested in building a new gaming system. I want to eventually go SLI and I want something that can really run new games at awesome resolution, seeing as I have a 21" widescreen now. So the last system I put together was a skt478 system, and I have sort of been out of the loop. I have been reading a little bit and I have a decent start on the components of the system. The only thing I havent decided on is RAM yet, but I have 1gb of pc4200 ram to start with.
Here is the start of the list. I choose the gfx card so I could go sli once the price drops on them some.
I would also like not to upgrade for at least two years if possible.
MB
http://www.newegg.com/product/product.asp?item=N82E16813131540
GFX
http://www.newegg.com/product/product.asp?item=N82E16814150105
CPU
http://www.newegg.com/product/product.asp?item=N82E16819103546
PSU
http://www.newegg.com/product/product.asp?item=N82E16817256001
Now I am not sure about the CPU. Newegg shows the 4800+ as being like $200 more than this one, but it only looks like it is 200mhz faster.
I would rather have a modular psu so if some wants to throw out some reccomendations.
That looks good but a 7800GTX? I heard the 7900GT is cheaper, cooling, and more quiet than the 7800GTX with the same performance.
Thank for the heads up on the 7900. Are there better brands to look for? I know that BFG is good and so on, better yet who should I stay away from.
I have been and Ati fan for some time as well as Intel. There products arent impressing me right now and I want to eventually go sli so I will give Nvidia a chance.
From research I've done....
- eVGA (most people say they are the best)
- BFG
- XFX
are good, they all offer a great warranty
Stay away from
- Sapphire (charge an admin fee to RMA your card, and you will have to wait 6 weeks to get your card back)
- Powercolor (only a 2 year warranty on all cards. x1900 series has a lifetime warranty but only if you live in Canada or USA)
yea definitely go EVGA with the 7900GT, in the case you get a faulty card, their RMA process is easy and quick. All their cards have lifetime warranties, and in the case your card no longer is in production they will send you a current gen card closest in value. Not to mention "stepping up" is simply awesome. If you buy the card and they come out with a new series within 90 days of your original purchase date you can return your card for the original bought value towards the new card.
BFG, eVGA, and XFX are the three brands you should look at with nVidia cards. I would go with the 7900 GT or 7900 GTX. The ATI X1900 XT and X1900 XTX are very good choices as well. I'm going to use the XTX in a new build i'm doing. The X1900 and 7900 cards are pretty evenly matched with one being a little faster then the other in different games.
As far as CPU's go i would not suggest the 4800+ or any of the really expensive dual cores. Your best bet is a good overclocking dual core like the 3800+, 4200+, or 4400+ and also the Opteron 165 and 170. On the Intel side the new 65nm dual core Presler is a very good choice as well. The 920 or 930 can easily clock towards 4GHz and higher and at that speed they have no problem keeping up or besting an overclocked X2 in the majority of applications. The new 65nm dual cores also run much cooler and actually stay within temps of what you would see on an X2. The 920 is also only around $250 and is the CPU i will be using in my next build. Conroe is also around the corner which should offer some incredible performance compared AMD's new AM2 and its said that Conroe will be supported on the current 975X chipset motherboards from Intel. Intel and AMD both have good options for processors right now. Intel makes the best chipsets on the market so i'm going to give Intel a try this next build after my last three builds all being A64/X2.
