Trying to locate a persistent crash... gurus... help?
roach9
I've reformatted many times, this crash is a constant throughout all of the reformats. I cannot narrow it down. I've changed my hardware many times and the crash has persisted.
Can anyone help me out here? Google searches haven't been able to help me out as of yet so I'm hoping someone here is smart enough to be able to figure this one out for me.
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2012-07-25T04:16:38.928809500Z
EventRecordID 5056
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Andrew-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
I haven't overclocked anything; my power supply is a 750W XFX Silver rated PSU that's pretty new.
Running i5 2500k, P8P67 Pro, 8GB Ram, 6870 XFX, Asus Xonar DX audio card...
ANY idea at all what this could be? Pretty desperate here.
Thanks guys!
(Windows 7 Ultimate - 64 bit)
Despite the PSU being fairly new, it could be the source of the issue.
What parts have stayed in place when you have swapped parts in and out? Have you tried a different power supply?
Not exactly a top shelf manufacturer that you have listed as the supplier of your ps.
Ok, so after 5 days without the error, it reappeared.
I took a look at the error that occured at the same time as the crash and here is the output... I think this might be telling and it signifies a driver issue, but I have no idea how to troubleshoot drivers! I haven't installed any erroneous drivers either.
Any idea?
- System
- Provider
[ Name] Service Control Manager
[ Guid] {555908d1-a6d7-4695-8e1e-26931d2012f4}
[ EventSourceName] Service Control Manager
- EventID 7026
[ Qualifiers] 49152
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x8080000000000000
- TimeCreated
[ SystemTime] 2012-07-30T03:11:17.099159100Z
EventRecordID 5710
Correlation
- Execution
[ ProcessID] 528
[ ThreadID] 532
Channel System
Computer Andrew-PC
Security
- EventData
param1 cdrom
I assume you have minidumps enabled?
If not enable minidumps and download whocrashed.
Run Whocrashed it will most likely tell you what is causing the issue.
I recently had an issue with a computer named Andrew-PC as well it could be the computer name :D
+1 for PSU issue or your sound card take that out of the system.
