Shadow Talyn
- Jul 7, 2004
Ok, this is the case that I am getting: Lian-Li 12-Bay Silver Aluminum Case With side window, Model "PC-65"
http://www.newegg.com/app/ViewProductDesc.asp?description=11-112-024&depa=1
I want the case to have in addition to the rear motherboard ports, Audio Out and Mic In jacks in the Front of the case connected to an onboard Front Audio connector on the motherboard.
Has anyone installed audio ports before? Anyone know where I can get the hardware to install them from? I do NOT want additional USB/Firewire or anything else added, I only want the audio ports. I was thinking what I could do is drill out the plate on the bottom and add them next to the case's preexisting USB ports.
Any Ideas would be helpful.
Thanks!
Thanks!
