Tengis
- Jun 11, 2003
I had another thread about a yagi antenna I built (I built two of them) but Im having trouble getting it to work as well as I expected so Im coming here for advice.
Basically, here is my situation. Im stationed in Japan (USAF) and the internet option we have on base is absolutely horrible AND insanely expensive. Advertised speeds are 20mbps while actual speeds are 1-2mbps with a data cap of 150gb... all for the lovely price of $120+ depending on which package you are forced into.
With two towers less then 1 mile from me I decided to roll with a wireless wimax option that has unlimited bandwidth. Best case scenario speeds are 50mbps down and 15mbps up. I get around 4-5mbps on average down and 1-2mbps up. The signal strength on the router is rated at 1-5 bars with no way to read the strength other then a x/5 fraction. I typically get 3/5.
The antennas are internal and very small. Here are some pictures of the internals and my yagi antennas:
I tried the antennas with and without baluns with similar results of 2/5 signal or the occasional 3/5 signal. Im connecting them with a 1.5 foot section of RG174. Ive got some u.fl connectors to RP-SMA to go from the router to a suitable connection to connect antennas.
I used this website as the guide for both of those antennas and used a different yagi calculator to figure out how to make the balun:
http://www.ab9il.net/wlan-projects/wifi6.html
Do you guys suggest I try a different antenna type? I was thinking maybe a double bi-quad antenna like seen here:
http://martybugs.net/wireless/biquad/double.cgi
Thoughts? Im just not sure what to do at this point. I have no other options for internet since I am stuck living on base and the physical internet they allow onto the base is slow and expensive with a low data cap.
