I need to forward ports 9000 and 2051 for a security system. I have tried two different routers with no success. The first was a Linksys WRT110. I followed the directions. Forwarded the ports to a static IP I put on my laptop. The IP is outside of the DHCP range on the router. I have internet connectivity.
Then I went to http://www.yougetsignal.com/tools/open-ports/ and checked the ports. They are still closed. I shut off the firewall on my PC and had the same results.
Then I tried doing the same on a TP-LINK router and had the same results. The ports are closed. I then connected my laptop directly to a DSL modem that is set to bridge mode. Obtained an IP on the laptop and tried to test the ports. They are still closed.
What am I doing wrong? Is there something I need to do on the PC to open the ports other than shut off the firewall? I do not need these to be open on my PC. I am just using it to test the forwarding of the ports for this security system.
