Carbon_Rod
- Apr 2, 2012
I got fed up with the driver crashing on me every 2 days under Windows... I need to try something else. So I figured I would try Ubuntu (or ANY Linux really... Ubuntu is just the first one I thought of).
But I'm getting hung up on trying to add the GPU slots to the folding client. Whenever I go to add a GPU to the client, it says something like "...GPU 0 not found" or "No more GPUs". I'm using the "nvidia-325" package found on the xorg-edgers repository. Everything looks to have installed correctly. I've also tried updating GPUs.txt, no luck.
After installing the nvidia drivers, everything seems to work after a reboot. I can pull up the nvidia control panel and both GPUs are listed there.
Tried using the latest folding client (7.3.6) under Ubuntu 12.04, 13.04, and Xubuntu 13.04 all with the same results.
Any ideas?
I'm about to try installing Fedora to see if it gives me any different results.
EDIT: I had this problem even when I first tried to install the folding client and get it working in Windows. At that time, however, I just went into the BIOS and disabled a bunch of onboard devices I wasn't going to use and then I was able to add both GPU slots. I tried the same thing this time with my Linux installs, and I still can't add GPU slots because the folding client doesn't recognize any of the GPUs.
Any ideas?
