Hellsadvocate
- Feb 20, 2008
I've been playing with computer hardware for a while, and i'm a bit new at this.
This is my current system:
Q6600
P4M890T-M2 motherboard
2 GB DDR1 533 Mhz
800W Ultra PSU
8800GTS 640MB
(This configuration doesn't work because the ECS motherboard doesn't support more than the dual core processors, so it just hangs after POST even though it recognizes the CPU if anyone knows if it is indeed my motherboard's incompatibility thats causing this problem please let me know)
My new configuration is as such:
2 GB DDR3-1333mhz OCZ
Asus Deluxe P5E3
(This is a backordered so I expect it near the end of march)Intel Q9450
And my same old 8800GTS 640MB
My motherboard and memory are on their way, so my new setup will be all of that, with a Q6600 which is just a 1066FSB, which is okay for my RAM I guess just won't get the performance I need. My question is, how long will this build last in terms of practicality? what kind of performance can I expect? reviews for this stuff are up but most websites are using QX6750 or something as the processor.
Thanks for the help guys, i'm new here and it's my idea that everyone here knows a shitton about stuff like this. Any help would be appreciated as i've had a ton of problems in the past with my setups.
Q6600
2 GB DDR1 533 Mhz
800W Ultra PSU
8800GTS 640MB
Asus Deluxe P5E3
