Trying to future proof my rig, need some help :)
krelkor
ok, below this is my current rig ive been adding to off and on for about 4 years
Asus A8N-E
Athlon64 3000+ single core @ stock 1.87ghz
ANTEC trupower 430w
2x512 Buffalo tech Pc3200
ATI X800GT - 256bit 256meg
Im not looking to do a huge revamp, mostly because i just spent a ton of cash on a 24" lcd
basically im wanting something to hold me over for 6 months-year until vista is more well adpoted and DX10 cards come out
Also, socket 939 is kind of being phased out eh? so no reason to upgrade the processor when the board could be outdated soon
So i think the theme of this revamp is cooling/overclocking/futureproofing
Current case isnt exactly tiny, but its not very well laid out, so i dont have room for any video card longer than my x800gt, also the cooling is horrible.
Because overclocking needs air flow... i was looking at this, also i think there is room to fit an 8800gtx or whatever, so it should be ok for DX10 cards?
Antec nine hundred
http://www.newegg.com/Product/Product.asp?Item=N82E16811129021
Along with this, i plan on using an artic cooler 64(god damn that is a sexy price)
http://www.newegg.com/Product/Product.asp?Item=N82E16835185125
Additionally ill be using an artic cooler x800gt cooler that exhausts out the back of the case
So, since these parts are kind of outdated, i wanted to overclock these as far as they will go on air
Hence, i need a decent powersupply, my antec is already on its last legs
also, i need something that can power a DX10 cars, maybe 2 in SLI in the future, along with 3 or 4 Hard drives and optical drives
I was looking at at something modular as well, because they're a little bit cleaner i guess.
Silverstone ST75F
http://deadeyedata.com/shop/index.php?main_page=product_info&products_id=95
seems like an amazing deal
Should i look at getting other ram? its the old winbond chips so i think they'll OC pretty well, or should i just invest in some new ram
Guess thats it.
thanks!
If you want to dip your toe into the overclocking pool, start first by reading all of the stickies and guides available. Then commence to apply information to your current system as is. If the airflow is poor, modify your existing case.
Do not waste your money planning for what may be in three to six months. Prices drop every month on cutting edge technology. Buy after the introduction wave breaks to maximize your return. Save your money and make a plan. There is no such thing as future proof.
hey thanks
ive done overclocking before, so thats not the problem, although it was in a different rig with different components
i guess that huge ass rant is more asking....
hey will that huge PS be enough for 2 DX10 sli cards, zomg
and will that huge PS and the largest vid cards today fit into that case without too much trouble
this hardly seems as fancy a post, lol
That PSU should do two GTS cards no problem, and while it isn't necessarily certified for it, two GTXs will most likely be fine. The Zeus 850 is certified (also has another 16a on the 12V), but costs about $80 more.
I'm not sure whether the PSU will fit in the case, so I can't help you there.
As for the whole setup, you should consider going dual core especially if you multitask a lot. Prices for those procs are around the $150 mark for an X2 3800 and about the same for an Opteron 165.
