Trying to find a certain mobo.
CLock3
Hello. I'm putting together a budget mATX build because I have a case laying around that I'm gonna try to update a bit and I've found a couple of parts for cheap, so I may as well put them together, haha. I figure it'll just be a good computer to let fold 24/7 and have it in the place for anyone to use you know? Anyways, I'm looking for an mATX board for cheap, preferably with a PCI-Express slot, because I've got an old 6200LE i'll throw in it. Also, it has to be socket 478. The only one I've managed to find was this biostar. It's not terribly expensive but if there's anything cheaper, or if someone on the board is selling one (i didn't see anything in the FS thread) let me know. Basically, I just need a mobo and some RAM, and possibly a power supply (i have an old one laying around, but it probably isn't enough for this), and then I should be good to go. Thanks in advance for any help. I appreciate it.
EDIT: Newegg has an open box for a little bit cheaper, but it probably wouldn't have the IO plate for the back. Would there be any negative effects of running it without that on it? Thanks.
