Trying to find a case that is really small
Karandras
Ok, the mATX mobos for 939 w/ PCI-e are a little slim pickings so I'm looking for a case that can support a 939 ATX board that is quite small. I'm seen the mid towers and they are too big. Any suggestions for a case?
Here is the system I'm building:
A64 3000+
1024 PC3200
6600GT OC
2x200gig SATA (possibly 3 for RAID)
don't know a mobo yet since I want to find a case first.
Thanks!
Take a look at Shuttle's products, first.
Those are as small as you can go.
EDIT: Do you want to build a Q-Pack or SG01? If that is the case, what features are you looking for?
Yeah, I was looking at the q-pack, never seen that SG01 before but looking at it, pretty sweet. Airflow looks a little blah in that box, that's the main reason I was looking at the q-pack.
I thought shuttles had all propritary mobos, haven't read much on those quite yet but I was also looking for a super quiet system (so the box can't be too small, I want to fit a Zalman 7700 in for CPU cooling).
I was also looking at the ANTEC ARIA case as well. Since you have the SG01 w/ 7700 in it, what do you think? (You being TELSA)
I have the 7000 but the 7700 should still fit.
I love it and have posted tons of comments in my thread.
The Shuttle MBs are proprietary but many people prefer them; I do not, however.
In my opinion, there are currently only two real choices for mATX motherboards using s939 out at this time, the MSI and the Jetway Pro. Are you planning to over-clock? If so, then the Jetway Pro board is most likely your best bet. (The ECS board is alright as well but with only 2 RAM slots. There is a NV chipset board out, too, but I have heard of many problems with it.)
Within the next few months we should see things change for the better in terms of mATX; it is your call, but you may want to wait and see.
EDIT: Also, the Q-Pack is the best "no-hassle" case for mATX. I do not like how it looks, though. The Aria is nice but you will need to drill it out for more fans.
I was hoping to OC, but if there is nothing available quite yet then I might not be able to. I think I'll look further into the qpack and go from there.
Thanks
