Need a creative networking solution. Any help is greatly appreciated. I'm an absolute novice in doing this, but enjoy doing it.
Here's what I have
6 computers and 1 copier all connected together on a 8 port hub (no internet) (everything cat5). It's just a simple peer to peer network.
Here's what I need to do:
Hook onto a wirelessG router with a satellite broadband connected to it so I can share the broadband over the network both wirelessly and to a possible 8 hardwired computers
I also need something to expand the range of the wireless because the access point will be a little more than 300 feet where some need to access it. My router will be downstairs in a far corner of the building and most the work takes place upstairs about 500 ft away or so. It is a steel building if that makes any difference.
I don't know if there are any 8port wireless routers out there (can only find 4 port), if not, what do I need to put together to accomplish what I need. I have a wirelessB network in my home but too ignorant to know how to expand the range or add another access point to expand my coverage.
I know it's probably some simple solutions, but I would appreciate any advice.
Thx
Here's what I have
Thx
