Trying to Decide...
richardatkinson
I'm looking to invest in a new power supply for the rig in my signature, and i'm torn between the Fortron Blue Storm 500w, the OCZ Modstream 520w, and the Enermax Whisper II 535w. I figured i'd post here to get some opinions and see if there's anything i don't know that would tip the scales. Thanks.
EDIT: I've decided on the Enermax Libert 500w, thanks for your input. :)
Check out the Enermax Liberty series ... they are strong, stable, effecient, quiet and modular
Check ou the Seasonic s12 series ... they are strong, stable, effecient, quiet and modular [ the higher wattage units are modular ]
richardatkinson said:
hrm, i like the enermax libert 500w, but it's a bit more expensive at 134.00. damn.
Where are you shopping? Liberty 500W is $99 at ATACOM.
