Trying to decide on a video card, help please!
Leaderz0rz
Intel Core 2 Duo E8600 Wolfdale 3.33GHz 6MB L2 Cache LGA 775 65W Dual-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115054&Tpk=e8600
ASUS RAMPAGE FORMULA
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131284
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003&Tpk=Xigmatek HDT-S1283
XIGMATEK ACK-I7751 Retention Bracket
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233019
Corsair 750TX 750W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006&Tpk=Corsair 750TX 750W PSU
Two sets of G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
2x Western Digital Caviar SE16 WD6400AAKS in Raid 0
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218&Tpk=Western Digital WD6400AAKS
Western Digital Caviar Black WD1001FALS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
SONY 22X DVD Burner w/ LightScribe Black SATA Model DRU865S
http://www.newegg.com/Product/Product.aspx?Item=N82E16827131059
Operating System: Vista 64bit Ultimate
Resolution: 1920 x 1200
That's my build and I am trying to decide between the 4870 x2 and 280
I primarily play WoW as I am a guild leader and raider leader so having my system crash mid fight or slow to crawl is not really an option. I also play a lot of TF2 and have started to play Red Alert 3 and I am looking forward to Dragon Age, SC2, D3, and others. Obviously this system isn't built around just WoW but it is a major thing that I need to have running smoothly.
I have been reading posts about the 4870 x2 having a lot of crashing issues with WoW due to a problem with powerplay. It seems sapphire has released a bios fix for theirs but I do not know if any other company has or is having the same issue. There is also the problem with running in window mode or alt-tabbing causing the 4870 to go into "2d" mode and clock down. I usually run WoW in window mode and alt-tab like every 20 seconds it seems :p
Then with the 280 I hear the horror stories of the nv4disp infinite loop being really hard to get rid of.
I don't care which card I get as long as they work. I mean dumping 600 dollars on a video card and then being stuck with it due to return policies it not something I am keen on. So I appreciate any insight you can give me on these issues that might guide into purchasing the right card.
Why don't you just get 8GB of RAM? They are so cheap anyway and you are using a 64 Bit OS. My vote goes to HD 4870X2 eventhough I don't play WoW anymore. You could also wait for the HD 4850 X2 which is cheaper than the HD 4870 X2.
I am getting 8gigs, Two sets of the 4gb g-skill.
I don't mind the price as long as it works, I don't want to purchase something that will not work correctly and be stuck with it.
I went with the 4870x2 because I didn't want to have to buy two separate waterblocks for more performance. From the benches I've seen the 4870x2 is significantly faster when crossfire scales well. I think on Crysis games though the nvidia offerings have an edge due to drivers.
I went with the Evga 280 SSC edition. I really wanted to get the 4870x2 but I just kept reading post after post about crashes,fps drops, alt tab problems, bad support for older games (WoW) and I just couldn't do it. Thanks a lot guys for you help and I will probably need more when I get my parts :p.
great choice and GREAT company. if i were in the market to buy right now i'd go with a 280 as well. can't go wrong with EVGA either.
