Heres a good illustration of the differences. at the beginning of April, I switched over to -advmethods on the SMP client. Previously, i was simply running two instances of the standard console client to load up both cores on my core2duo E6600. I didnt really know that there would be such an extreme difference between the two, or that my machine could be making 3-5 times the amount points as it was. So for all you people running standard clients, check this out...
previously- i was making a garbage 300 to 800ppd total running two standard clients. with SMP that is now up to 2500 or so ppd; or one 2k point WU every 12-18 hours. as you can see, 8 days into the month of may, i have more points in 9 WUs than i got from the 58 WUs in the whole month of february.
the reason i was running standard clients is because thats just what i was used to for a few years, there was never a post that i found that outlined clearly the differences or said what would be best to run for my given hardware. so il say this-
anyone who is running the standard client on any computer with more then 1 CPU should upgrade NOW. any CPU with 2+ cores should be running SMP.
go here
http://folding.stanford.edu/English/DownloadWinOther
and download the one that says "6.29 beta for MPICH (32-bit or 64-bit)" (its the last one on the page, but above the two "unsupported clients" on the very bottom.)
go here and read about and get a passkey
http://folding.stanford.edu/English/FAQ-passkey (click 'where do i get a passkey?')
enter your passkey into the client after you install it. you wont get the bonus points until you have successfully completed 10 work units. CTRL+V doesnt work, but you can click on the top left corner of the FAH console (on the molecule picture) and in the menu click edit>paste if your passkey is in your clipboard.
done. after 10 WUs, your PPD should skyrocket. there are plenty of better guides in the stickies at the top of this sub forum if that was unclear to you. oh- and the only team number you need to remember is 33
go here
