Hello all. I've been shadowing the forum for a while, but figured it is time to join this great resource of information. I've been outside the loop of hardware and gaming for the last 4-5 years. I just built myself an i7 rig, and I've been debating on which video card to get. System specs:
i7 @ 3.8
6gb @ 1333
22'' display @ 1680x1050
Current video card: Gigabyte 4350 (my backup video card)
Initially I was thinking the gtx 285, but I'm really don't think I need it at this resolution. Now, I'm thinking of getting the 4890 as it is $100 cheaper than the 285, even though it is probably still overkill. My goal is to play crysis with little/no lag, and therefore max out most other games as an extension of this goal. I would like the card to have some headroom in terms of future games.
What do you guys suggest I do?? It seems like a good time to buy a card.
Thanks!
i7 @ 3.8
6gb @ 1333
Thanks!
