- Dec 17, 2007
So my friends ACER Aspire M3641 motherboard failed. I bought a new one to replace it ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813500058 ) The problem im running into is the front I/O connections are wrong. The motherboard has the standard male 4 points on top and 5 on the bottom ( PW, PW SW- HDD, Reset SW) and the connector (female) from the case is larger with more connections. I cant get it to seat because other things are in the way. Any recommendations? Is my only option to give up or buy a new case?
There are some others things, like it only has 2 internal USB ports and theres 3 wires but thats inconsequential compared to the power/reset buttons on the case not doing anything.
To be clear, all she really wants is her HDD, because it has Vista on it with all her accounting work etc. I have backed up all her IMPORTANT stuff but obviously getting the drive back ASAP would be best for her busniuess.
Thanks guys.
Thanks guys.
