I believe the Noctua only comes with one fan, but that's better than the TRUE, which comes with none. It saves me money and more shopping, although I most likely will go with a push/pull config anyway.
That's tempting. Those Noctua fans really are ugly. I used these for my T-Rad2 cooling my 4870, and they are very quiet and work well. However I don't think they move enough air.The SE1366 ver. comes with two fans but I believe is around 70-80 bucks, wile the NH-U12P is about $60. the TRUE can be had for $49.99 without a fan. And you have many choices for good fans in the $10 range, you will end up with a better cooler and not paid anymore for it. Then if you ever feel like it you can lap the TRUE and have a really awesome cooler.
If you don't want to lap, then the Noctua is your only choice because the base of the TRUE is really convex. Also the Noctua performs better at the same price because it comes with two fans, or at least my version did. However, a lapped TRUE with two fans in push/pull would beat a noctua.
I'm into little weekend projects and the pressure mod seems as easy as adding a washer/penny/piece of cardboard. Is there anything I'm missing with the whole pressure problem?Very, true. Lapping is such a pain and lapping a TRUE takes forever. Plus, the mounting system on the TRUE sucks so you have to play around with that, too. A lapped and pressure modded TRUE will net you better temps, but Im not sure if all of the effort is worth it.
I figure I need about $100 set aside for this project...sigh. I have a huge spending problem.Not at all. It's that easy. I needed two washers stacked together. I wish that I had used bigger fender washers, though. I used 2 1/4 washers about 3/4" in diameter, but the next time that I remount it Im going to use 2 1/4" washers 1 1/4" in diameter. Also the lapping isn't too bad, it's not fun but not that bad. It might be worth it for you to pick up a TRUE. I love mine.
What about these? They move a good amount of air while staying beneath the 25 dB threshold already in place with the Antec Tricools in my Nine Hundred case.
Couple things - from all the metrics I've seen, 2 fans on a TRUE or U12P does not increase heat dissipation more than a negligible amount. Second, the Noctua are relatively low pressure fans - which makes them OK as case fans but not the best choice for a heatsink.
Also keep in mind those heatsinks (especially the HR-01+) are specifically designed for use with low speed fans - so throwing on a higher speed 38mm fan would be sort of defeating the purpose. A TRUE with a 1,200rpm Scythe will cool an overclocked Yorkfield just fine.
That was my point, you aren't getting better cooling. It's a less efficient means of cooling than a single fan pushing. The best cooling for a processor is turbulent airflow being pushed over the surface, which is provided by the fan that is pushing, which is unrestricted on the intake side. The fan that is pulling is going to be grossly less efficient. Moreover, the point of low speed fans is to reduce noise - but it is a proven fact that using two fans in place of one more than doubles the noise produced. In other words you would be better off with just a slightly higher rpm single fan than two lower rpm fans.
Thank you Stellar. Two fans doubles the noise though? Shouldn't the noise level just be a little higher than with just one fan?
uhh, heatsinks are designed to be put in whatever position, weight shouldnt be a problem unless your using the intel stock pushpins (which will probably still be fine) which isnt the case for the noctua since it has its own lock-in system.What do you guys think of the weight of these heatsinks? Would use of the noctua be risky if the case is standing up and not laying down? Last thing I want is to rip out the motherboard due to the sheer size of the cooler.
to the guy who said noctua fans aren't good for heatsinks because of pressure is referring to the older s12 fan that was made for case use and had little static pressure, the new p12 was designed to be used as a heatsink and case fan and has very good static pressure, notice why noctua packs their heatsinks with them.
thought I'd clear things up![]()
i dont think the true comes with a crossbow like backplate to secure it, but i know the noctua does if that helps.
you can buy the crossbow for the true online as well.
yeah no problemHey thanks a lot for that response, just wanted some peace of mind since the last time I built a computer the cpu coolers were a lot smaller.
