My 2500K @ 4.7 tops out at 60 with my TRUE at full load. I'm pretty sure that the Hyper212 tends to do 70.
Are we talking about the Thermalright Ultra 120 Extreme?
I am getting around 70C at 4.5Ghz. What's your vcore?
I'm using the "auto offset" feature of the Asus Pro board. It always stays under 1.4v, sometimes getting into the 1.38 range
It's still one of the best air coolers on the market.
I don't think the washer mod is necessary anymore. The new mounthing hardware for the 1155/1556 socket holds the cooler very tight.
Mine is runs pretty hot, but I'm using a slow quiet fan and my voltage is a bit high.
My 2600K @ 4.7 get to 85C with 1.41v and a 1200 rpm fan.
How do you get your TRUE mounted on your MB? do you use an adapter? I'd like to see if my TRUE is more efficient at high loads than the CM Hyper 212+ I now use.
Isn't 85 degree be too hot specially with TRUE? I thought that these 2nd generation Ci7 are as cool as Wolfdale
