It most definately is possible. When manufacturers rate their pumps, the GPH figure they use is with 0 restriction - absolute maximum flow. As you add more restriction, the pump is bot able to keep the same flowrate as it was able to achieve before. For example, look at this Overclockers.com review of a Via Aqua 1300 pump, comparing with several other aquarium pumps in realistic loops (restrictive by today's standards). For another comparison of older pumps (with a flow vs. pressure loss graph, known as a PQ curve) check ProColling.com's comparison.CoW]8(0) said:But for most WC systems, would it be to have a possible 75% drop in rated GPH for a pump through most cooling loops?
ikellensbro said:For many people, if they wished to find out their loop's flowrate, a simple test would be to time how long it takes for your pump to fill a measured container with your loop fully connected, including its block(s) and radiator(s) at the same heights they would be in the functioning loop.
