TRUE fan question
SirKronan
I have the Asus P5Q Pro motherboard. With overclocking the EPU engine doesn't work, which makes it largely worthless to all but the wimpiest of users ... :p
The Asus fan control, at least for my board, only really works on the CPU fan. I've NEVER been able to get Riva tuner to work with this board for anything other than reporting fan speeds. No control whatsoever.
The main CPU fan works just fine with the ASUS AI Suite. I would like to mount a pull-fan on the other end, however. Is there a good way to control it automatically with this board? I mean, as temps increase, so does fan speed, like the regular PWM fan. Can I make that happen somehow on this board with the second fan?
I'd rather not use a manual fan controller. I'm already using one and it's all filled up with chassis fans. I'd rather the CPU be automatic anyways. It worked really well on my 780i board with their ESA software, but I couldn't overclock my quad worth a darn on that thing. Can you "split" the PWM fan output without damaging anything?
Thanks for any suggestions you guys have.
Well, if you could find a 4 pin y cable you *could* run two fans off that connection.
I did a quicky search but was unable to find one, but you might be able to / or make one.
I have the LIAN LI PC-A70B case & ABIT IP35-Pro Motherboard.
I looked into have a push/pull fan setup but my case has a 120mm exhaust fan approx 2 inches from my TRUE.
I just have one Sythe S-Flex F on the TRUE and another one on the case as an exhaust.
This has wokred very well for me.
Not sure which fan you are using now, but those are well worth the money.
if you want real fans, invest in some EBM Papst high quality German engineered fans. They have basically three lines of fans, quiet ones, high performance fans, and their extreme performance S-FORCE series of fans. They are very expensive, but the quality is far better than any other fan manufacturer can offer.
PAPST does sell thermal regulated fans, but they are for high temperature situations like ovens.
Having thermal regulated fans is a bad idea, a fan always running at a decent rpm will be a much better idea than having a fan throttle up and down.
For quiet operating fans, go with fans which have sintec sleeve bearings, they are quieter than ball bearing fans. SIntec sleeves generate less motor noise than fans with ball bearings.
K-TRON
With the overclock I have and the voltage I'm cranking to my processor, I need a flexible fan system. My current fan is a surprisingly excellent Cooljag that pushes 120 cfm at 100%. And the noise is actually mostly air, not fan noise. It's an impressive fan.
My CPU idles at 34c. But at full load with this amount of an overclock (and me still being air cooled) it'll hit the 60c range. I've done stress tests and going from 50% on that fan to 90-100% yields a 10c drop!! The TRUE has so much fin area, so air flow is KEY. I need a fan to be flexible enough to spin up and bust out the high CFM when my processor gets that hot (which is rare that it will be all four cores at 100% load) but I don't want it in the 70's, even if it's just once in a while. That would be harder on the processor than I want to be. That's why I'm thinking of going push-pull on this setup. I have some extra fan clips and I know the TRUE is designed to do it.
I just wanted some Ideas on the best way to go about it.
If the exhaust fan is fixed, and doesn't change speed, will it do any harm if the main intake PWM fan is capable of frequent speed changes based on temps?? Can it hurt anything?
And should I have the more powerful fan exhausting, or intaking??
