Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i have just had my second pump fail on me so im thinking of ditching the water all together how far behind watercooling is the TRUE or any air cooler of that spec many thanks for any replys
a lot more people use air cooling now thanks to today's heatsinks, it's not all that far behind, the load temps will be higher obviously so you can't push it as much as water, but you can definately get some good results.
