Hi all,
So, I've been lurking in the UltraSharp threads for over a year. Lots of great info and insight to be had here, and last year I ended up getting a u2211h. It's a great display... except that, as documented here and elsewhere, these 6-bit/A-FRC panels don't play very nice with some Macs, causing a 'pinstripe' dithering artifact for certain colors. Whereas the problem could be mitigated in Snow Leopard, 10.7 Lion makes the problem resistant to any troubleshooting or workarounds.
First, a sanity check: although it seems the case based on my reading, do you folks think that the problem is being caused by the fact that the panel is 6-bit and uses A-FRC? If an 8-bit panel can indeed rectify this situation, what would be the best budget option to replace the u2211h? All I've found so far are the HP ZR24w and the Dell u2410, but they're larger and more expensive. Are there any 21.5" panels out there that are true 8-bit? I suppose I could also track down a 2209wa, but I'd likely notice the drop in resolution.
Thanks for anyone who can point me in the right direction
