TRUE 120 fan help
Ru7hl355
hey guys,
ok i have a Sharkoon 2000 Golf ball fan currently running on my cooler, its rated at 76CFM(supposedly).
i have 4 Scythe Slipstream fans coming tomorrow, rated at 110CFM.
my question is, will it be worth me swapping my sharkoon for one of these slipstreams?
i know i have to take back pressure into account, but i dont know which fan handles it better.
i also have a fan controller coming so i can control these suckers
you could always record your temperatures that you get with the sharkloon, then change it with a slipstream and compare the differences that you record. It's really hard to tell which fan will give you a better result because manufacture ratings are almost always false or not accurate.
