It comes with 775 mounting gear and AM2 gear. It also comes with two 120mm fan clips and possibly thermal paste, but I don't remember that specifically.
For 775 you'll need to use the mounting bracket, the backplate, and the 4 longer screws (AM2 uses the shorter screws).
Remember, TRUE 120 does not come with a fan.
FWIW, I have used medium speed (2000rpm) 120x38 Panaflo on several installations with satisfaction.
You might also investigate SpeedFan......
thanks =] , i was just making sure. I wonder how difficult its going to be to install, i know the instructions that came with my XP-90 were a joke.
I picked up a Scythe Slipstream 120MM 110CFM fan =].. im excited that ill be retiring my vantec tornado.. ill be able to sleep with my computer on again!
I wish petras delivered faster though! I ordered my mobo, vid card, and fan monday morning and had it all by tuesday afternoon! the TRUE120 from Petras wont be here till the 27th!
