So I was playing City of Villains the other day, and then without (apparent) warning, the screen went into standby mode and wouldn't display anything at all. It "sounded" like the rest of the PC was fine, but I couldn't get anything to respond (like the windows key to shut the PC down or ctrl-alt-del for example.)
The computer will boot up, as in, the LED lights and fans come on, I hear the typical wake-up beep, but no windows noises are heard and it doesn't seem to do any processing "thinking noises" after the fans come on. It just sounds like it's in standby or something.
Here's what I did so far:
1. I manually turned it off thinking it was a monitor problem. Cords were all plugged in, all is normal back there. Used the monitor on another computer and it's just fine, so it's not a monitor problem.
2. Replaced the video card with two other cards, stil won't post. So I don't think it's a video card problem.
3. Replaced the video card cables, just to be sure, and used my vid card cable on someone else's system... no problems. So I don't think it's a vid cable problem.
4. Since the LED and fans turn on, I think it's not a PSU issue but I'm not 100% of course.
So this leads me to think that it's either a Harddrive issue, Mobo issue, a RAM issue or a CPU issue... How can I get more specific? ( I'm going to transfer the harddrive to another computer to see if it can be accessed tomorrow. ) Is there a way to test to see if it's a RAM problem rather than a Mobo issue? Or CPU, etc? What happens when the RAM fails & the Mobo is ok, or visa versa? Will it turn on like mine does?
Thanks for any advice...
(BTW this is the system in my signature that's acting up.. I plan to buy a new system soon, but I wanted to wait til April 22 when Intel cuts prices...
