Troubleshooting Laptop USB Ports
mda
Hello all,
I have a Thinkpad P50 Laptop with 4 USB ports, 2 in front; 2 at the right side.
I have an issue with both USB ports on the right side, where USB storage will no longer detect after the computer has been on for quite some time (3-4 hours). Other items like USB mice will always work though. Power doesn't SEEM to be an issue though. The USB storage device will light up / USB HDD will spin up.
The back ports always work.
A restart usually will fix this.
I'd like to take it in for repair, except it will be a PITA to migrate my work files to another computer since I don't have another computer that will take an M.2 at present.
Is there anything I can do to troubleshoot this at this point? I have already tried:
1. Turning on 'always on USB' in the BIOS
2. Doing the same in the Lenovo power settings
3. Disabling USB selective suspend setting in the Windows Power Options.
4. Disallowing the computer to turn off the USB ports in the device manager.
There doesn't seem to be any newer USB device drivers I can update to at this point.
I am running Windows 10 64 Bit.
It sounds like a software/driver issue by the way this problem seems but I can't be sure nor do I have the time to spend one whole day at the service center just to demonstrate to them the issue.
Wondering if anyone has encountered anything similar or would have any idea as to what could fix this kind of problem.
Thanks
have you disabled the power off setting for the external drives in device manager? not on the usb posts but the drive itself. if so and all other options for usb power saving are off, id suspect the Lenovo software still screwing with things. maybe uninstall it to test.
Thanks for the reply.
The USB drives I have tried all show up under "Disk Drives" in the drive manager. What this means is unfortunately these don't give me the option to disable the power off setting in the device manager. Also doesn't show any power option for my other drives (a 960 Evo and an 850 Evo).
Will try uninstalling the Lenovo software for a day and testing. I hope this isn't the issue though -- I only really use the software from keeping my battery to charging to full, since my laptop is plugged in most of the time.
ok. then have you turn off hdd power down in the power plan settings? that's the only other thing I can think of at the mo' other than turfing the Lenovo software.
I have already set the hard disks to never turn off. (I suppose this is why they don't show up in the device manager?)
Forgot about that one though.
I really hope it's not the hardware. I can't afford the work laptop sitting in the service center for another 3 months wasting the warranty away :|
The odd thing is, things like USB mice will work perfectly, and that the USB devices get power. It's just that the device isn't actually detected.
due to the other devices continuing to work I would suspect software or settings, not the ports themselves. do the drive have any software that came with them? not exactly the same as your situation but my hp external usb 3 drive came with software that allowed you to control the power savings on the drive.
ps: do they only do this on the laptop?
The tested devices only do this on this laptop and I can't lock down what makes the laptop begin not detecting drives on the right side USB ports only.
The tested devices are:
1. WD 1TB 2.5" USB powered
2. Sandisk Extreme 32GB
3. Sandisk Extreme 128GB
4. Logitech G602 receiver
5. Some other logitech mouse receiver
4&5 will ALWAYS work on the right side USB ports.
1/2/3 will ALWAYS work on the right side USB ports after a reboot.
I've also tested devices 1/2/3 on a Synology NAS that was on for several days already as well as my 4770K system (which can be on pretty much the whole day) without any problems.
I will try an el-cheapo USB stick when the drives fail to detect on the right-side USB ports once again.
It's also funny in an infuriating way that the two rear USB ports never have this issue.
do you have two different controllers or is there only one in device manager? mind giving me the full model #? gotta hit the sack its almost 2am here so ill take a look in the morning.
There seems to be only one controller
Under Device Manager --> Universal Serial Bus controllers:
1. Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
2. USB Composite Device
3. USB Root Hub (USB 3.0)
This is my laptop
Type: 20EN
6700HQ
CM236 chipset i think
16GB factory default RAM
The only thing I did to this was to replace the 500GB 2.5 with a 960 Evo, and to do a clean install...
Couldn't really tell if this is the default behavior for this machine since my initial one shipped with two bad right side USB ports already.
hmmm id try the newest intel chipset driver. see if that helps. I looked at that model last night and they don't have a new chipset driver or anything related specically to the usb. but the chipset driver from intel is worth a try as it looks like its just using MS's built in driver. I honestly don't think the drive change would have any effect.
Thanks for this.
Will give it a go and update within a day or two.
Unfortunately every test I perform means I'll need to wait till day end to be able to test if there is a difference since a fresh boot will mean it will always be working...
Had a port shut down on me again. Needed reboot. Seems one port is affected more often than the other. Looks like a hardware issue then?
So out of 4 USB ports:
2 Back Ports - 100% ok
1 Side Port - seems to have problems intermittently (will need to confirm if this port in particular will always work as well)
1 Side Port - will stop detecting storage eventually
the only other thing really left to try is a bootable windows usb stick(on a good port) or maybe on the old or a spare drive. just to eliminate any software issues. then after that id say its hardware. you should be able to find a bootable usb image or how to make one. its a pita but the most thorough way and could save you down time if an rma isn't needed.
Thanks. With the time spent troubleshooting this thing, I may as well just send it in for RMA.
What are the chances, 2 motherboards, both with USB problems...
well you gotta weigh the rma time vs troubleshooting time and decide if its worth it or not. you might want to hit the google and see if anybody else is having the same issue and maybe send Lenovo an email. the chances of two mobos having the same prob usually comes down to if its a manufacturing defect that affects the entire line. if there is such a prob they will usually correct it and release a new rev version.
Yeah debating between just leaving it be and just keeping the wireless mouse receiver in that slot instead.
The frustrating feeling of getting a partly defective brand new 1200$ part though...
yeah I hear that. did that with stuff before but begrudgingly so...
Check to see if you have eHCI or xHCI handoff disabled or enabled in the bios and try the other option. Might be a controller FW issue that can be remedied by using the software or vice versa.
Will check around with that. Thank you! In the meantime, the USB port was running fine yesterday.
I have no clue what I did :O
Just happened again today after 5.5 hours of uptime. Can confirm that the issue is relegated to that one port. Had my USB mouse receiver plugged in the port when I started the day. I wonder if that's causing issues.
Inside of the mouse receiver (Logitech G602) seems dirty/black. Receiver shorting the port out?
Will try to play with the receiver sitting in another port tomorrow.
Edit: Well, happened again with nothing in the USB port. This time with another side port. The more I troubleshoot, the more frustrated I get... My semi OCD may just compel me to get this fixed.
Just to update. Annoyance took the better of me. Moved back to my old laptop and sending the thing to the repair center. Going to drop this off since I have an errand right beside the repair center. Took two videos of the thing malfunctioning twice. Hope that's enough.
