System make and model...
Dell Optiplex GX50 (as stated in the title, lol). It's in Dell's (very) old "mini desktop" style case (PCI card cage and desktop-style optical drive). I got it from the local tech shop; I'm friends with the owner and he said that "it had some kind of problem" but that I could probably sort them out. I'm a little less confident now than he was then...
Yes, I know it's very old, but if I can make it work I'd like to. I'm funny that way
The problem, in a nutshell...
System will not boot. Some lights but not fans or anything else -- no POST beep, no nothin'.
Specifically, regarding the lights... the power LED blinks amber and there is a bright orange LED on the motherboard (I believe that this is the standby LED). In particular, the diagnostic LEDs in the back of the system do not light up at all.
What I have done so far...
(1) Replace PSU with a compatible part from a different system. Both are odd, proprietary slim PSUs, although the ATX connector is standard. The original one is 110w; the replacement is 180w.
(2) Temporarily removed PCI card cage.
(3) Temporarily removed BIOS battery (I don't have a spare battery anywhere, really
(4) Temporarily removed the "Password" jumper (that's what it's marked as on the motherboard -- there does not seem to be a jumper anywhere labeled as CMOS Clear).
(5) Temporarily removed RAM, leaving one slot open and one slot occupied each time (2 slots total).
(6) Disconnected drive power (but not data cables) for all 3 drives (optical, floppy(!), and HDD).
Other things worth mentioning...
- No components on the board seem overly hot. (I have not felt the CPU.)
- I have not replaced the CPU itself or the BIOS battery. I do not have spares for these right now. CPU is an SL5FQ (P3 1B GHz -- 1000/256/133/1.75), and I have no other skt370 CPUs (gave them away to a friend and fellow [H]er a year or so ago IIRC >.< )
...at this point I suspect that the motherboard is toast. Mostly what I'm looking for here is a sanity check -- motherboard, CPU, or something that I did that I should not have done?
EDIT: just plugged a Dell 200w ATX PSU in to give it another go. That one is known good... lots of coil whine but nothing else changed
