Working with my girlfriend's father's PC, so I am not intricately familiar with it's setup. I'll come back with more details after I collect them, just wanted to make a generic post to see if it was some simply solution.
INITIAL PROBLEM: The PC was not powering up, only the front LED would come on, no fans, no hard drive spinning, nothing. I replaced the power supply and everything seems to power on just fine.
CURRENT PROBLEM: Now the PC starts the booting process. BIOS comes up, everything seems to be working fine, however there are some issues.
1) There's a constant regulary beeping noise as long as the PC is running (beep, pause, beep, pause, beep, pause, etc.). I haven't tried counting them yet to see if there is a longer pause, but I will.
2)During the booting process a few things happen that I've never seen. It does what appears to be some kind of IDE scan? Also displays an option to enter the RAID setup menu, so I assume the PC has a RAID setup (2 HDDs). When Primary Master is displayed it simply says "None". Furthermore, later on, it displays,
HDD 1: not detected
HDD 2: not detected
HDD 3: not detected
HDD 4: not detected.
3) The Windows loading screen comes up and shortly after the PC simply shuts down. I was able to boot up into safe-mode once, but never again after that.
Any initial ideas simply based on the beeping or other issues when power supplies are replaced?
HDD 1: not detected
HDD 2: not detected
HDD 3: not detected
