Alright, let's get the hardware out of the way-
Motherboard: Gigabyte GA-P35-DS3L
Processor: Intel Core2Duo E6750
RAM: 2 modules of 1GB OCZ Gold DDR2-800 (5-5-5-12)
Graphics card: EVGA 8800GTS 640MB
PSU: An Enermax 535W
2 IDE hard drives (yeah yeah...) 1 SATA DVD drive.
Display: Samsung Syncmaster 750s (17" CRT)
Now, the story. I don't have a whole lot of expendable income. It took me a while to save up to build a new system, and I was really hoping that it wouldn't have any problems this time (fifth time building a computer... fourth time running into headache-inducing problems). But that would be too easy! So, I order my parts, they're delivered earlier on today and I get to building.
Everything's properly connected, I hit the power switch... all the fans start spinning, but nothing comes up on my screen. It sits there with the light blinking as if it were in standby mode. I switched the monitor connector to the other DVI port on my video card, same thing. I powered everything down, reseated the video card and tried again. Same thing. I reseated the video card a couple more times, along with the RAM and the problem persisted. The monitor doesn't even flash for a second, it's just not getting anything from the video card.
Some things that might be worth noting-
- I use a DVI->VGA adapter because my monitor doesn't support DVI. However, my monitor's VGA connector does not have 3 full rows of 5 pins. Some pins are missing - not fallen off or broken, they were never there to begin with.
- When powering up the system, I do not hear any POST beeps at all. Not a single beep to confirm a successful POST, nor any error beeps. I will assume (unless told otherwise) that the successful POST beep is turned off by default so that only the error beeps will be present.
To answer any questions before they arise-
- Yes, the case speaker connector is properly connected to the motherboard.
- Yes, the GPU fan spins on powerup.
- No, I did not electrically shock any of the hardware. I'm very careful about it.
- No, I do not have a spare motherboard, processor, RAM or video card that are compatible with the new motherboard for me to test it with, nor do I have a spare monitor.
The only thing I can come up with right now is that not having the full 15 pins for the VGA connector is resulting my monitor not picking up any signal... though, I'm not really sure how accurate that is or even if it's possible. Any help would be greatly appreciated. It will take me about a month to replace any part of the new system so if I can't get it working with what I have, I'm sort of SOL.
Thanks for reading, looking forward to any responses.
