Wolfdale75
- Jun 17, 2010
Hi Guys,
I'm trying to set up a direct cable link between two XP PCs. According to the books and online directions, this should be a cakewalk, but I can only partly get it to work. Can anyone help?
Is this kind of connection supposed to be bi-directional? I.e. you can read and share both ways? Or is it only for migrating data from one direction to another?
Will it only work if both PCs are running the Pro version of XP?
I tried it between my new PC and two other PCs. One, my old PC, would only let me access a shared folder on one occasion. Other than that I can only see the old PC on the network but not access it. The other PC I tried with, a netbook, I can see but not access. I cannot see the new PC on either the old PC or the netbook. When I click on the view workgroup computers option under My Network Places on my old PC, simply nothing happens. Instead, I should be able to see the new PC there via the direct connection.
Below are the theoretical steps I have taken which should be getting it to work:
1) Get a Cat5 crossover cable
2) Perform a loopback test on both PCs
3) Make sure both PCs have TCP/IP, and File and Printer Sharing installed
4) Give both PCs unique names and put them into the same Workgroup
5) Set up simple sharing under the Folders applet in CP
6) Ensure both PCs are set to receive Remote Connections under the System settings
7) Ensure Windows Firewall is allowing Remote Connections and File Sharing
8) Set 1st PC IP address to 192.168.1.1 and 2nd PC to IP address 192.168.1.2. Both have subnet mask of 255.255.255.0.
9) Select a folder on one of the PCs, right-click and select Sharing. A small hand icon appears under the shared folder.
10) Now you can view the shared folder on the other PC via My Network Places and then Entire Network
