Trouble with P55 FTW 200
magoo
I added some upgrades to my son's computer this weekend......
Now the system won't POSTcold unless I reset the CMOS.
He has.....P55 EVGA FTW 200 S1156 MB with i7 750 CPU.
added 8 more GB of 1600 memory, now 16 GB of 1600 Vengence 1.5V memory @ 1.55V, not OC'd
Added two GTX 980 4 GB GPUs.
PSU is HX 850
Has a 250 GB SSD and two 750 GB HDD.
Board HAD been running a minimal OC.....Bclk of 175 x 20.
VCore 1.35V, all other settings on AUTO
This had been rock steady for 4 years.
Now, after the reset with clearing the CMOS, I can reset the BIOS to :
175 Bclk x 20 @ 1.35V and the system will run all day without a problem.
It will even warm restart.
But if he turns the system off overnight....it won't boot.
Any suggestions?
Is it possible the cmos battery died? Take out the new 8gb ram and try same settings as before? Try with one 980 instead of two? Might take some trial and error, but who knows at this point what is causing the problem. You could add a notch to the vcore, it might be that the IMC on that 750 is weak, needing a bit more for more ram usage.
I would also try the above suggestions. You may be cutting it close on the power supply requirements. And wow two 980s, you are a nice dad lol.
I've already looked at all those above suggestions.
I ran each memory stick individually in memTest and then installed one at a time....nothing.
The GPUs were handled the same. They were taken out of a fully functional system.
The 980 is pretty low power. The total draw is about 600 Watts at full load in this system.
I'm going to try and boost the VCore a little today and see if that makes a difference.
I did enable "no VDroop" and disable the lower VCore at start up, the BIOS is set to use the same VCore without variation.
Its weird that this is only a "cold boot" issue and will run all day like a rock once it gets going.
The cold boot issues still happen with only 2 of the mem sticks installed? or just one of the video cards? Interesting indeed. Have you tried to source a replacement CMOS battery for the board yet? I would look towards that next. You are correct that it is a low amount of load power, but I had multiple s1156 systems back in the day, and they were notoriously picky when it came to components, which is why I had suggested stripping the rig down to a more simple state. I am also curious as to whether or not the video cards are UEFI cards, as I'm fairly certain that s1156 was pre-UEFI. However, I am fairly certain that was mainly an issue with AMD cards, but I could be wrong.
Anything else change when you did the upgrades at all? system stability when in windows?
I adjusted some of the voltages in the BIOS and haven't had a problem since.
I had to go up to 1.375 VCore, no droop, and 1.0V on the VTT.
The BIOS has a low voltage Boot option and I adjusted that to meet the VCore as well.
I think maybe it was the low Boot voltage that was the problem.:cool:
