Long story short.
I bought two 7970 to run them at CF, even when i only run with PCI-E 2.0 x16 x16. I've done alot of reading and the conclusion was that i would only lose a few fps.
I'm running with a old i7 930 that have been OC'ed to 4.2GHz with HT on. Yes it's old, but it will do for now untill i build a new rig.
Here's some score from 3D Mark11
3DMark Score ~P13500
Graphics Score ~17500
I've compared at some reviews and my scores and almost equal.
Well, on to the problem. The cards runs great so far, but sometimes "ok, many times" when i play games the FPS is dropping down to 70-90 fps, to stay there a few seconds untill i move the mouse or change position/cruch/lay down. This is only tested at BF3 and Borderlands 2. Settings are at max with v-sync on and at res. 1920*1080 on a 120hz monitor.
What's even stranger is that neither CPU or GPU are using 100%
CPU stays at 50%-70% on all cores, and GPU are pending between 50%-80%
I don't know about you guys, but i thought that 7970CF was able to run BF3 to at least 110fps stable, at least at this resolution
What i've done.
*All drivers + AMD Cap + mobo bios are up to date.
*CF bridge are at place and CF are enabled in CCC
*No heat problems with CPU or GPU
*Disabled the graphic cards power saving in regedit
And some specs
*OS: Win7
*CPU: i7 930 @ 4.2GHz HT ON tested with Prime95 at 12 hours
*Memory: Corsair Dominator DHX+ 1600MHz 6GB,
*PSU: Corsair HX 850W PSU
What i've done.
And some specs
*OS: Win7
