Trouble running 2 GPU slots in beta 7
M0rph3us
So I want to run 2 separate GPU slots for my 5850 since 1 slot doesn't even use half of the gpu power. My problem is that every time I put a 2nd slot in my client freezes after like 30 minutes and stops working. Anyone got any advice to help with this?
You can't run two clients at the same time ....the low usage is due to the units being small....though iirc it should be more than 50%
