Trouble RAIDing Raptors!!!
explrsport
I have never had so many problems trying to get something working....the config is below. I have updated the BIOS, switched RAM, checked all cables, and now I'm stuck.
I am getting a blue screen of death when I try to install Windows XP Pro....error says, "Page_Fault_In_Nonpaged_Area". This happens after I press F6, load the Intel SATA Raid driver, and then get into the Windows install page. Windows cannot see any partitions, and then the system blue screens. Any ideas???
Abit IC7-G
(2) WD Raptor 74GB
Corsair XMS Pro PC3200LL
Had the same problem,
It's WINDOWS FAULT!
Just won't see the drives.
Once you setup your raid try bootin into dos , you'll see any IDE but no raid .
I installed on single ide channel then swapped out to raid and made the raid bootable. This happened on two boards .
maybe this will help?
