Trouble OCing my 2500
Bionic_Tuna
I can run the FSB at 180 on stock voltage just fine. But anything above that and windows won't boot, the comp just restarts itself right before the windows loading screen. Even after bumping the voltage up as high as 1.85...
I am using the Vantec Aeroflow HSF and my idle temp at stock at about 39.
I have PC3200 ram, what should the timings be at? Also, what percent should the memory frequency be at? Anything else I am missing that could be causing this? Thanks.
Soltek SL-75FRN2-RL nforce2 mobo
Barton 2500+ w/Vantec Aeroflow
2x 512mb Giel PC3200 memory
Radeon 9800 Pro
Audigy 2zs
wow, i dont know crap about tha mobo.
Are you running a Barton that is unlocked?
Why not bump volts more if temp is getting to bad.
what is timing of your mem at?
Check amdmb.com to see if the have a soltek forum, too.
