Trouble logging into Dell OpenManage
AMD_Gamer
I am trying to login to Dell OpenManage to manage my Perc 6 RAID Controller. I can't login and there are no real settings to change. I don't get why this is so difficult. Does anyone know why I can't login? what is the trick?
screw it, just going to use the DELL SAS Raid Storage Manager from LSI, works fine:
Umm... next time you could try checking the "Ignore Certificate Warnings" checkbox. It lets it bypass the self signed certificate OpenManage comes with normally.
That was not the problem, I tried everything. Doing research online it turns out Dell actually still recommends to use version 5.5 of OpenManage if you run into this problem. however that version will only install on an officially supported hardware.
