Hi,
I just built a new A64 rig w/ the following specs:
A64 3500+
ASUS A8V Motherboard
1GB CORSAIR TWINX RAM
ATI AIW 9800 PRO
AUDIGY 2 ZS PLATINUM PRO
PLEXTOR 712A DVD-R Burner (Set as Primary MASTER IDE Device)
PLEXTOR 5xxA CD-R Burner (Set as Primary SLAVE IDE Device)
WD 740GD RAPTOR (Plugged into SATA Channel 0)
Maxtor DX740 HDD (Currently unpowered)
MS USB NATURAL MULTIMEDIA KEYBOARD
MS USB WIRELESS OPTICAL MOUSE
I purchased a brand new OEM version of WinXP PRO w/ SP1a
All of the hardware except for the Audigy 2ZS and Maxtor is installed. I can boot up fine, and go into the bios.
I tried using the custom Windows XP installation bootdisk from Bootdisk.com - but had problems using the AEFDISK program (I couldn't format the Raptor as an NTFS drive) so I decided to boot from the CD, and have Windows set up NTFS partitions and format the drive. I planned to reboot once the drive was formatted, copy the i386 folder to a directory on the HDD and do a clean install from there.
When I boot off the CD, windows loads its drivers in the dos screen (during which time my keyboard is active.) Then it says "Loading Windows" or something to that effect, and gives me the option of a repair install, quitting, or a full install by pressing "Enter"
The problem is once this screen pops up my keyboard is no longer on. (Numlock/Caps lock light is turned off, and no key presses are not registered.)
I no longer have a PS/2 keyboard - any suggestions? This is really frustrating. (Out of 3 systems built recently, this is the only one I've encountered with this issue.)
I tried enabling PnP OS in the BIOS and there was no difference.
Thanks in Advance.
A64 3500+
ATI AIW 9800 PRO
Thanks in Advance.
