Trouble installing Windows XP Pro
Kalakaka
I just built a new computer for my mother using some spare parts that I had laying around. I'm trying to install Windows XP Pro. Everything is going okay up until I get to the screen where you're asked to press Enter to setup XP, press R to Repair or press F3 to quit setup XP. At this point, my usb mouse and keyboard do not work. I made sure to enable USB Mouse support and Keyboard support in the bios. I even switched out keyboard and mouse. Still no go. the odd thing is the keyboard and mouse will work up until the spot. Any suggestions?
you may have to look for an old ps/2 mouse.. sounds like the drivers for them arent on the windows xp disc.. id make sure legacy usb is enabled in the bios as well.. or you could try disabling keyboard/mouse support and see if it works..
The "easiest" thing you could do is use a native PS/2 mouse and keyboard. Do you have a spare set available?
I may have an old ps/2 mouse and keyboard in the closet. I'll see if I can find them and give it a try. Thanks.
