TorryHolt81 said:it has 250 watts.... only have 1 hard drive running and 1 dvd rw writer running..
plus how can i switch modes on my power supply it says 115?
TorryHolt81 said:i have onboard graphics yes... no i have 1gb +512mb should i take the 512mb out?
TorryHolt81 said:why is the switch there in the first place... cant i just unplug the pc and switch it and turn it on? because the other side says 230 im guessing that runs at 230 watts..if i cant means i have to upgrade my psu?
TorryHolt81 said:yea my bios doesnt have the option to disable onboard graphics justs 8mb 32mb and 64mb
Terra said:It's not 115 and 230 watts.
It's 115 and 230 VOLTS!
and in the US it 115 VOLTS...don't touch..you have been warned now
Terra - BIG difference!
TorryHolt81 said:thats probably how my hard drive burned up.....
mentok1982 said:Alright then.
Unless Terra or other knowledgable persons suggest otherwise I say go shopping for a power supply.
TorryHolt81 said:one one like it shows
agp/onboard next line it shows
pci
if i pick agp it enables onboard...
TorryHolt81 said:whats a jumper? i ebayed a 450 watt psu would that be enough?
rofl!!!!!TorryHolt81 said:i switched it and turned it on... and it didnt start up... but then i switched it back and it was fine... was i lucky?!?
mentok1982 said:The card does need a molex connector, but most cards will do everything except for go into 3D mode without being plugged in.
His PSU is probably fried because he switched the Voltage on it earlier. He killed a hard drive because of that as well.
mentok1982 said:NO!!!
Do not touch that switch ever!
