Trouble installing DB9 Serial to PS/2 adapter. Help!
BurntToast
I am working on a Dell Optiplex GX620.
On the users old computer they had a PS/2 device. But their new GX620 doesnt have any PS/2 ports. So they need an adapter for their old device.
I already tried a USB to PS/2 adapter and that didnt work. The device was going in and out.
So I picked up a 9 pin serial to PS/2 adapter. So far it isnt working. Nit even when I plug other devices into the adapter (mouse/keyboard).
I went into the bios to see what serial was set to; it was on AUTO. So I changed it to COM1. Not even that di anything. I also set the port to legacy PnP, nothing happened.
So how do you think I should go around getting this adapter and device to operate on this machine? It acts as if the computer doesnt even see the device.
Thanks
DB9! I love DB9, that is what my old Macintosh uses. I suggest looking for another type of adapter. Sorry, I doubt that helped much.
What's the device? What operating system are you using? A PS/2 -> serial adapter won't work unless the PS/2 device is already wired to support the serial interface. What do you mean when you say the device goes "in and out"? Have you tried the device + PS/2 -> USB adapter on a different computer?
