Ok. I need some help here.
I just set up a wireless network as some know from the other thread.
At first, I installed everything and the net was running fine on the desktop as well as the network being recognised on the laptop.
There was no security as all as it was just put in place so I put everything on.
I disabled DHCP, added WPA-PSK security and entered the MAC address of the laptop so that's the only one that could use the network as outlined in the sticky guide.
Problem is, the laptop can't find the network at all and I can't connect to it.
I know there are some settings I need to change since DHCP is on by default, etc, but I'm unsure what I need to change and what to change it to. I have all the info (IP's, etc) in front of me but don't know which to change.
I've also got a long key word as for my WPA protection and apparently I have to enter this in my laptop so it can access the network but I can't find it anywhere.
If anyone can help me connect this laptop to the network it would be greatly appreaciated.
Thanks
Thanks
