Trouble Booting...
Verown
Hello everyone,
I just bought a bunch of parts from newegg, here is the list:
Motherboard: Gigabyte 965P-DS3(rev.2.0)
Ram: 2GB Corsair Dominator DDR2 800 mhz(PC-6400)
Power Supply: OCZ Game X Stream 700W
CPU: Intel Core 2 Duo E6600 2.4ghz
GPU: EVGA 8800GTX
This is my first time building a computer from the ground up, but I have pretty good knowledge of computers in general, so I'm pretty sure I've got everything right and that I'm just missing something small.
Just to note before: The motherboard was given to me by a friend who had used it once in his computer to test something out, but it was only tested for 1 boot.
When I turn on the computer nothing happens, the screen is blank but it does NOT say "No Signal". When I have something that doesn't transmit a signla my monitor will usually display that. All the fans are spinning, including the CPU fan. The video card is connected to my monitor via DVI-D and my monitor is set to DVI-D. I tried all of the settings on my monitor and nothing is showing up. I tried taking out the ram and putting it back in, i also tried the same thing with the video card. I have not cleared the CMOS or anything like that yet. Hope someone can help.
Try clearing the CMOS and did you make sure to attach the PCIe power cable to the video card? Just the first thought that popped into my head.
I took out the battery and waited for a bit, then put it back in. That didn't do anything. The PCIe power is plugged in on the video card. One of the times i turned on my computer I forgot to plug in the PCIe power to the video card and there was a really loud continuous beep. Other than that, I tried both things and none of them work.
silly but make sure your didn't forget the lifters for the mobo and reset your card.Also try 1 stick of ram and then the other. Also make sure everything is clipped on like the atx connectors and your 12V connector. Make sure you also have your speaker attached so you may hear the beep codes just in case you have a issue. I recently had the same problem so I know how you feel.
This is what I would try in this situation.
Ok, so I just took the whole thing apart and put it back together. I counted the number of screws I had in my motherboard and compared them to the number of lifting pins. I double checked when I mounted the motherboard that there were lifting screws under each hole. I took off the cpu heatsink, opened the cpu "door" and gave it a little nudge. I then put the CPU heatsink back on and clicked the pins in. Next I plugged in all the power to the motherboard and plugged the video card in. After that I plugged in the PCIe power to the video card and put in 1 stick of ram in the first slot.
The only things that are connected right now are the following:
CPU and heatsink
Videocard
1 stick of ram in first slot
All the power
I'm still having the same issue. I tried the other stick of ram as well, same results.
Note: I called one of my local pc shops yesterday and asked a few questions about this problem and the guy had told me to take out all of my ram and boot up to see if the motherboard would tell me anything. When I did that nothing happened, the computer turned on like it has been; no beeps, no nothing, just fans spinning and lights on. Hope someone can help here.
CPU and heatsink
Videocard
All the power
Hmmm, that seems very weird to me. :(
CPU and heatsink
Videocard
All the power
That would mean that there is either something wrong with the CPU or the motherboard. I think it's still a CMOS issue. Sometimes when you take the CMOS battery out and put it back in, it still saves the setting. Power down all the entire system and remove the battery and leave it out for maybe 5 - 10 minutes. Go get a drink or something and watch some tv, then come back. Try it again... Are you running a different chip than your friend?
Also, just for convienence (and to eliminate any potential shorts), I usually take the motherboard out and everything, set the system on my desk (set the motherboard on a motherboard box) and test everything out. Saves you a great amount of time if you have to keep removing stuff and all.
Did you put too many risers? If all else fails, You might have placed the CPU improper and damaged the pins on the motherboard.
