BillLeeLee
- Jul 2, 2003
So I've been looking at tripods and heads since I generally shoot at lowlight or in the nighttime (or indoors and I sometimes don't use flash), and I've been trying to narrow down my choices. However, I need some advice from the more experienced photogs and gear people.
Now, I shoot with D70, and currently only use two lenses - the 18-70 mm and the 50/1.8. Just been reintroducing myself to photography over the past half year and getting used to SLRs and such.
In my mind, I'll never shoot something on the level of a Canon 1Ds or Nikon D2x (you know, the heavy cameras) or small medium format and I'll probably never use a 300 mm/2.8 or greater. The highest I could envision myself using is a camera body like the D20 or a D100, and for a lens, the heaviest probably the 70/80 - 200 mm ones.
So it's not like I need a top of the line pro ball head like a Markins or Kirk, but something reasonable and still rigid with locked and smooth to move. I currently use a pan and tilt (some kodak), and ball heads are a lot nicer to use when I demoed them out at a camera store.
As for legs, I really liked the Manfrotto 3011Pro and 3021Pro legs, those would be good enough for me, and they're pretty lightweight.
Any suggestions? Or maybe I should just stick to my pan and tilt for now?
Thanks.
Thanks.
