Triplehead2go + KVM switch problem
qbert3
I have a triplehead2go (digital DVI version) and a Avocent switchview (dvi) KVM device. The triplehead2go works great by itself, I was using the resolution 3840x1024 (1280x1024 across 3 monitors) with it.
As soon as I tried to install it with the mentioned KVM switch, the highest resolution I could get with it was 800x600 on each monitor. Any resolution higher then that would cause 2 of the 3 screens to corrupt (the screens had color, but it looked like a single line of color stretched across the entire screen).
Any ideas? I tried enabling and disabling SLI, newest drivers for both the 8800GTX and the triplehead2go. Rebooting... everything still shows the same error. I think the KVM switch is the problem, just hoping I'm missing something.
PC Specs:
Vista 32-bit
Intel 6300
8800GTX (have a 2nd for SLI)
2GB RAM
This is good to know. I run a KVM between a Mac Mini and my PC on dual monitors. I was going to buya 3rd monitor and a TH2G. Hmm...
