Triple Titans: X79 or Haswell?
I hate upgrading at all since my 2600k at 4.5-5.0 ghz still gets the job done, but I need pcie 3.0. This will be a gaming rig only. So far Haswell is looking incredibly underwhelming.
Go for a 4770k for true pcie 3.0 support?
Or go for a 3930k to cop those extra cores and use the pcie 3.0 patch and hope for the best?
Im thinking of purchasing a third titan for my 3930k. The patch is doing fine for me. I don't think Haswell is going to be that much of a performance increase but who knows.
Clearly you're looking for gaming support. If you're using four Titans, I don't see how your CPU would affect performance in any way shape or form aside from using a benchmarking program. Four Titans will run games amazingly with even an i5 and below. Your question seems almost pointless. Go for 3930k and game on.
Btw AFAIK, the biggest benefit from Haswell processors will be seen in mobile computing, not desktop gaming rigs.
What's resolution? If your gaming at an extreme resolution with 3 titans I would say go x79
If this is purely for gaming, I wouldn't go with X79. If you must absolutely have the "best" then go for it though it's really not the best for gaming. Honestly, you're be better off with a 4770K (over clocked.)
Reality is, the extra cores won't help you as much as a higher clocked 4770K would.
there are spots in some games where even my 2500k at 4.4 cant maintain 60fps.
